Wheel offset modification - Wagga.
jex
Post by jex »
Does anyone in Victoria know of a wheel works in the Wagga Wagga area that can move a wheel Centre on a steel wheel i. e. Change the offset?
John
Re: Wheel offset modification - Wagga.
That's a long drive from the Sunshine Coast, or have you moved?
I'd suggest contact Smith's Speed Works in Wagga.
They may be able to help.
0412 694 408
jex
Post by jex »
Thanks mate, I am enquiring for a friend who lives at Tumburumba and thought that would be the closest major Centre?
John
Hi Jex.
Do you know how this turned out?
I know it's an older post but any decent engineering shop with a lathe and competent welder should be able to do that for you
