Louvres
Louvres
Just wondering if anyone had a contact number for Neil Stamp in Wangaratta as hei the only guy I know that does louvres in car bits. Any tips would be helpful. :wink:
Re: Louvres
Do you have a shop press?
You can buy the tooling from Hare and Forbes.
Probably be a lot cheaper and could make a bit on the side helping out others
https://www.machineryhouse.com.au/p1173
https://www.machineryhouse.com.au/p1174
Re: Louvres
Thanks Marcus worth considering, :wink:
Re: Louvres
Are you considering louvers on the pilot Chrisso ?
HOT ROD FRED
Re: Louvres
Post by HOT ROD FRED »
Keith Stamp is in Wangaratta.His brother Neil I think is in Bendigo.Keith was always the go to man for louvres, but since his stroke about 20 years ago, not sure.I don't have phone no's, sorry.
Jeff Hitchins
Re: Louvres
Post by Jeff Hitchins »
If you have a bead roller then Hare and Forbes also have these which might work depending on what panel shape you were working on
MBR-LST - Louvre Bead Roller Set $110 inc gst at present
https://www.machineryhouse.com.au/s6333
Re: Louvres
There is a gentleman in Wollongong who stamps louvres. His son is on the FB/EK Holden forum with the username Harko. A post or PM over there will likely find him.
http://www.fbekholden.com/forum/index.php
