water based auto paint
36 roadster
Post by 36 roadster »
I have some water-based paint I want to use (with urethane clear over the top), but am not sure if standard acrylic primer surfacer can be used as undercoat. The job I am doing is to touch up an area with some pre-matched water based stuff .
.....insert witty comment here.....
