Fitting a Vl Commodore power rack in my 47 with an Astra electric pump.
Can anyone tell which fitting on the rack the high pressure fluid goes to. The large one or the smaller one.
Thanks
VL Commodore Power Rack
Re: VL Commodore Power Rack
I will have a look at our VP tomorrow, I also have a GM manual for VB VC VH. Will look at that one for clues. Off the top of my head generally the small fitting is high pressure in . On my Jag rack this is the case , and the pinion housing is marked "In" "out" making life easy.
From the factory workshop manual:
Thanks for the info guys. Very much appreciated.
