Jag front upper shock mount (attn Peter @Toprodz)
chop_shop
Post by chop_shop »
Gday, since i cant PM, hopefull TopRodz see this this !...
I got some upper shock mounts from Toprodz for jag front end to run different shock, im just wondering what shocks i need to buy ?
thanks
Warren
― Albert Einstein
Re: Jag front upper shock mount (attn Peter @Toprodz)
I'm using the same brackets. Monroe 31089, or Gabriel 82001 The application is 1962 VW Beetle. There is a range of years, and this falls somewhere in the middle. Front and rear of the Beetle use the same shock.
chop_shop wrote:Gday, since i cant PM, hopefull TopRodz see this this !...
thanks
Warren
Try him on facebook Warren.
chop_shop
Post by chop_shop »
Gday, thansk for reposnses, will order up the shocks !....
cheers
Warren
― Albert Einstein
Newbee
Post by Newbee »
Warren, equivalent in KYB -
P/N 443045
Newbee
Post by Newbee »
P/N 443045
I have looked at my VW shocks ,no visible part number. On this f/e subject , I got somewhat peeved. I may have to lower the front end and of course remove the springs. My f/e is now fitted to the F1. When I did bushes etc and front end was loose, I used the large curved threaded bar down the guts s per the OEM Jag tool for the job. I found another method on a UK Jag Forum where in vehicle each bolt holding the spring plate was removed one at a time replaced by threaded rod and retained via nut. Once done, each nut is wound down progressively lowering the plate. The pictorial and write up quoted 1/2" UNF . I hunted some ,purchased qty 2 3 foot lengths, and a few days back they arrived. I looked at them and thought hang on these look too thick, removed one bolt from a plate ,they are more like 3/8" UNF. :oops: :roll: :twisted: . I re checked the saved web article. Yep 1/2" it says. :evil:
chop_shop
Post by chop_shop »
thanks Newbee, will look those up as well.... and Frank thats a bummer about the rods !
― Albert Einstein
Yes Frank the threads are 3/8" 16 tpi.
enjenjo wrote:Yes Frank the threads are 3/8" 16 tpi.
Thanks for that Frank.
Are you sure? I thought they were 3/8-24
The last one I did a couple months ago was a 1986 series III and was 3/8 by 16
Nissan Vanette rear shocks will work too
