Residual brake valve leak
Hey all. Residual valve in the brake lines seems to leak from the brass fittings that go into the alloy housing.
I have tightened them up as tight as I dare. The brass fittings are a tapered thread.
Should there be any sealant on them?
Any clues?
Any clues?
Re: Residual brake valve leak
Tapered threads should not require any sealant.
What Dany said!!
I had the same problem On the last car I did. The problem ended up being the brass fitting. I replaced it with a different brand fitting and no more problem. Not even some teflon sealant helped the first fitting.
I fitted three yesterday and all three weep from both sides
Hi Litidv8
Its the tapered thread, we do not use taper thread fittings on brakes here in Australia its a USA thing.
You are mixing two different systems together and it does not work.
Try a brake specialist for advice or adaptors
Thanks David
Thanks David
Hi Litldv8
What vehicle are we talking about ?
Drum Brakes and 10 psi Residual Pressure Valves ?
Disc Brakes and 2 psi Residual Pressure Valves ?
1940 chev pickup. Master cylinder is under the floor. I am using a 10 lb one for the rear drums and 2 lb ones on the front discs. Will post some photos when I work out how to.
Good tip. Everyone of these I have purchased though has come already fitted with the brass adaptor.34 tub wrote:Hi Litidv8
Thanks David
It's the brass adaptor leaking where it goes into the valve
Neil
Neil
Hey all it would appear that I think I have solved my drama. The brass adaptors are damaged where the Bundy tube flare seats on the adaptor. So I have sourced some steel adaptors and used some sealant on the thread where it goes into the valve. So far so good. No leaks. Thanks for the advice, Neil
