C4 auto dipstick boot
monte
Post by monte »
I am trying to buy a rubber boot for a C4 auto that goes into the case to seal the dipstick ,anybody got an idea where I can buy one ,thanks :D :D :D :D
chop_shop
Re: C4 auto dipstick boot
Post by chop_shop »
G'day, pretty sure its just an O-ring right and not a boot as such ?
― Albert Einstein
monte
Post by monte »
chop_shop wrote:G'day, pretty sure its just an O-ring right and not a boot as such ?
This is an aftermarket one and it has a rubber boot where it goes into the case of the auto ,the rubber seals it inside the case hole and the top bit is expanded so it is supposed to seal on the top but mine is split and leaks when sitting ,driving me nuts ,i hate oil leaks .The original ones had a couple of o rings on them that sealed inside the hole and they worked ok ,really stupid idea from ford and the later ones went to a pan fill that bolted it ,great idea :D :D :D :D
I think turbo 350 - 400's use a similar one Monte . :idea:
Oldcol
Post by Oldcol »
...good idea Scott, make him use a Chev part :lol: :lol:
Oldcol wrote:...good idea Scott, make him use a Chev part :lol: :lol:
:D :D :D :D :D :D
rx4ord
Post by rx4ord »
He'd rather have the oil leak I reckon!!
Poor Mont :shock: :wink:
rx4ord
Post by rx4ord »
monte
Post by monte »
46 deluxe wrote:I think turbo 350 - 400's use a similar one Monte . :idea:
Yer i saw the chev one and wondered if it was the same ,sure looks like it :D :D
monte
Post by monte »
rx4ord wrote:Or is this it??
https://www.ebay.com/itm/Ford-C4-Transm ... 0712791652
Helpful Dave
That's the one Dave, now to find one in AU
Greg N Smith
Post by Greg N Smith »
It appears that most C4's with the dipstick / filler tube going into the case (not the pan / sump) had O ring seals on the tube but some used Monte's boot
https://www.ebay.com.au/itm/Filler-Tube ... SwBvNToegw
https://www.ebay.com.au/itm/Ford-Mustan ... SwrV1de0dt
https://www.ebay.com.au/itm/Ford-C4-C10 ... xyWmxSVydg
Is the boot only for aftermarket dipstick tubes ?
monte
Post by monte »
Yer Greg its the 3d one and its an aftermarket thing ,but seems nobody in AU sell the boots ,the original ones were ok with the o ring or maybe some had 2 o rings but some of the aftermarket shit had an o ring on the top that is supposed to seal the hole in the case but it dont work cause thats not how it was designed ,I put one of them in the new project and its still leaking fluid everywhere ,the flexible ones look ok too and might save up for one of them as I dont have a lot of room to play with :D
See if you have a tranny joint up there Monte , they should be able to supply one or tell you where you might get one .
46 deluxe wrote:See if you have a tranny joint up there Monte , they should be able to supply one or tell you where you might get one .
Careful Monte.
Walking into a tranny joint and asking for an O ring could get you in all kinds of trouble! :P :P :roll:
