Re: 54 Hudson coupe
I’ve got the car up in the air a little bit, to run brake lines. The front is done. The rear line is going to run down the passenger side with the fuel pressure and return lines. I will be setting the pinion angle and welding the spring perches while it’s up in the air too.
Twin Spinner
Re: 54 Hudson coupe
Post by Twin Spinner »
8) :mrgreen:
hudson nut wrote: Thu Aug 01, 2024 11:48 am IMG_1037.jpegIMG_1036.jpegI’ve got the car up in the air a little bit, to run brake lines. The front is done. The rear line is going to run down the passenger side with the fuel pressure and return lines. I will be setting the pinion angle and welding the spring perches while it’s up in the air too.
8) :mrgreen: Love those old Hudson Coupe's. Thanks for posting :D
Re: 54 Hudson coupe
That rear quarter with that fat tyre and stance just looks perfect to me. :)
Re: 54 Hudson coupe
Nice low roofline, keep plugging away Dany.
Re: 54 Hudson coupe
We don't see many Hudsons in Australia and a coupe is even rarer.
Looks pretty tough the way it sits.
I like the fenderwell headers.
