Mudgy
Re: 54 Hudson coupe
Post by Mudgy »
Now that's NICE......
jailbar joe
Re: 54 Hudson coupe
Post by jailbar joe »
top job danny exhaust's are a bugger of a job....but you have nailed it....well done
Re: 54 Hudson coupe
Finally finished with the 57 Chevy pickup, and the 52 Hudson Hornet that needed brakes, (for a friend with Parkinsons, and can’t work on his own cars anymore).
I worked today on trimming back the inner fenders to fit around the headers. I still have a little more to cut away, and I will add some material forward of the header, above the upper control arm.
It was nice to get to work on my own car again.
Re: 54 Hudson coupe
Good to see you back at it.. :)
Re: 54 Hudson coupe
Two photos are an uncut, right side inner fender. There is an indentation and slot, where the upper control arm went through, that doesn’t work with my application. The third photo is the left side, with that part cut out, and a patch clamped in place to fill it. I still need to file the fit a little bit, and fix up a dedicated 220 volt outlet for the tig welder. That won’t happen until next weekend.
Re: 54 Hudson coupe
Got the 240v plug in, and finished welding the inner fender panel, then trimmed again to fit around shock tower and header. Still a little fine tuning to do, then clean up the welds and finish the edges.
I’m slow, but it’s progress.
Re: 54 Hudson coupe
Great to see it moving forward and taking your time on the details. :)
Re: 54 Hudson coupe
Started on the other side. I’m a lot happier with how this side looks, and I will be making the other side look similar.
robtus
Re: 54 Hudson coupe
Post by robtus »
Can I suggest you buy a few rolls of yellow masking tape and protect all the finished parts while you are still under construction. Amazing how man scratches you end up with no matter how careful you try to be.
Re: 54 Hudson coupe
robtus wrote: Thu Feb 23, 2023 10:44 am Can I suggest you buy a few rolls of yellow masking tape and protect all the finished parts while you are still under construction. Amazing how man scratches you end up with no matter how careful you try to be.
Good idea. I do cover the headers with rags when installing or removing the inner fenders, but I like the tape idea. Thanks.
Re: 54 Hudson coupe
I got my brake pedal and master cylinders yesterday. These won’t take up a lot of space in the engine compartment. I’ve never cared for the under floor units. No booster required. 10:1 pedal ratio.
Re: 54 Hudson coupe
Re: 54 Hudson coupe
Lovin the updates very cool 8) 8) 8) 8) 8) 8) 8)
Re: 54 Hudson coupe
I have always loved that pedal setup.
Re: 54 Hudson coupe
Same here with a dislike for under floor brake set ups. To fill the master cyl without a remote reservoir requires carpet lifting etc, In our 49 F1 pickup I found a late 80,s/early 90,s Toyota Landcruiser pedal box /pedal an ideal fit. Stock Landcruiser booster and 7/8 master cyl stops the pickup we. Running Jag f/e and stock F100 rear drums on a 9" rear. My other dislike for floor pedals was the need to seal the pedal floor .holes from draughts and water. Returning from our honeymoon in Jan 74 from Sydney in our 35 Coupe we encountered rising flood waters on the Hume highway north of Wangaratta, got through in first gear with two jets of water hitting my lap. :shock:
