Re: 54 Hudson coupe
Pedal bracket done and assembly installed.
Re: 54 Hudson coupe
A little update.
Re: 54 Hudson coupe
I picked up a few boxes of butyl based thermal and sound barrier. I started with what I think will be the most difficult piece of the floor, the transmission cover. After 6-7 hours, an a lot of slicing and dicing, this is what I ended up with. This is tedious, but I got it all covered, except where the accelerator pedal goes, and with no overlaps
Re: 54 Hudson coupe
Impressive!
Re: 54 Hudson coupe
Adapting my 54Hudson steering wheel to a 67 Cadillac tilt and telescoping column.
Re: 54 Hudson coupe
Now to attach the wheel to this hub.
robtus
Re: 54 Hudson coupe
Post by robtus »
Looks like a really nice wheel for your car. I had a similar issue and solved it by welding a new centre in. Click my website link below then click steering and scroll down. This is a photo from the process.
Re: 54 Hudson coupe
Nicely done robtus
Re: 54 Hudson coupe
Done, except for making it pretty.
Re: 54 Hudson coupe
Looks good, great job.
Re: 54 Hudson coupe
What a sweet looking steering wheel.
Re: 54 Hudson coupe
I didn’t think I had enough projects half done, so I took my instrument cluster apart in preparation for the new gauges from Speedhut. I’ll post up pictures when they arrive in a couple of weeks.
Re: 54 Hudson coupe
Love your work.
Great mix of traditional, stock and late model tech. Really well done.
And back to under-floor vs firewall mount master cylinders. I spent my misspent youth battling the under floor master cylinders. Then I bought an FC. So easy!
Just something I observed: We here in Oz have it relatively easy when it comes to brakes.
If your (Australian-based) car has underfloor brakes, at least the master cylinder access hole is easy to get to. It's right near the driver's door, so lifting the carpet is fairly easy.
Not so with left hand drive cars. The brake pedal is right next to the transmission tunnel. So the access hatch is harder to get to, and you have to lift a bigger section of carpet.
Ditto with firewwall brakes. We here in Oz have the master cylinder close to the right hand side of the firewall, next to the right hand side cylinder bank ( on a V8). More room.
robtus
Re: 54 Hudson coupe
Post by robtus »
Agree with firewall mount brakes. I only open the LH bonnet side on my 34 to show the engine, and have deliberately made that the 'pretty' side. All the ugly stuff is on the drivers side and who cares anyway. I hate holes in the floor or firewall, last car to have one was an FC in 68 when I tried to make a cheap heater.. With road noise and engine noise reduced, plus easy access in a space otherwise un-used it is a no brainer. I recently helped a friend make and fit a heat shield to his booster under his 32, it was, and still is, less than 1/2 inch from the exhaust.. I made an alloy cover to go over the plastic reservoir on mine, details on my page, link below.
All the best for 2024...
Re: 54 Hudson coupe
I got my gauges yesterday. 2-5/8” Volts and fuel level on the left. 4” GPS speedometer, 2-5/8 water temp and oil pressure on the right. Turn and high beam indicators built in to speedometer.
