1945 Austin 10
Tappet Head
Re: 1945 Austin 10
Post by Tappet Head »
Tappet Head
Re: 1945 Austin 10
Well Ive mucked up on the Springs and need the pin location moved, will see If I need new springs or can have them repinned, Bugger. Having issues with ankerman, steering box location, etc, all the shit. wish I need to source different steering arms, with less drop, and link hole on closer to center line of car to correct ankerman if there at the rear, need to move it out for the front and cant find arms to suite ford, there all dropped, should of went chev.
Anyone got any idea's?
chris spokes
Re: 1945 Austin 10
Post by chris spokes »
i used eh-hd holden steering arms on my model a with the round back ford stubbs , they are strait and from memory you just need to enlarge one hole 8) you may be able to use fc-fe i just remembered it was a kingpin front end so they may fit
Tappet Head
Re: 1945 Austin 10
[quote="chris spokes"]i used eh-hd holden steering arms on my model a with the round back ford stubbs , they are strait and from memory you just need to enlarge one hole 8) you may be able to use fc-fe i just remembered it was a kingpin front end so they may fit[/quote
Yeah Cool, I'll hit up Ians Chassis design, ya just rung a bell im my head and he uses old holden bits
Tappet Head
Re: 1945 Austin 10
Ed Roff inspired Shifter and seats arrived, so mounted it to ensure its not gunna foul, and to help with floor planning, dummied seat into position, hoping to move it forward a touch more later. Spoke with Ian and have dummied up the front and have a plan that I know will work, just gotta make it happen now.
Tappet Head
Re: 1945 Austin 10
Started on firewall and floor planning. You can see how far back the front and engine are, have a few ideas there, using teh same seats out back but with out the head rest and set up for easy removal if required when racing.
Tappet Head
Re: 1945 Austin 10
Got some pics of the front end, its finally sorted, and the rear end is awaiting laser cutting and its sorted, Rads getting designed atm, motors in the shop for machining, on the way is all the final steering parts and once here all in I just have "basic" sheet metal work on the floors and fire wall to complete. then if happy build the cage, I wanna drop the lid about an inch so holding of the cage until I have sorted out what I'm doing there, but I'm also thinking to convert it to a coupe if I chop the roof. gotta look at what I have on my build sheet approval and what I can do there,
Re: 1945 Austin 10
Foot room is tight once you make the trans tunnel, but that is to be expected with these English cars.
Great to see your progress coming along and be interesting to turn it into a coupe.
Or just shorten the whole thing! :D
Re: 1945 Austin 10
How are you going to fit a clutch pedal in the footwell?
chris spokes
Re: 1945 Austin 10
zuffen wrote: Mon Apr 24, 2023 9:34 pm How are you going to fit a clutch pedal in the footwell?
pretty sure it's auto Rod,
good to see your still moving forward on the build 8)
Re: 1945 Austin 10
Chris, you're right. Just as well or he would need tiny feet.
Tappet Head
Re: 1945 Austin 10
Went Auto because of that, but If I set myself back further I can fit it in.
Tappet Head
Re: 1945 Austin 10
Been a bit tied up lately, got a side project and got distracted, but trying to get a few things sorted, I have drawn up the rear suspension brackets and just gotta cut them, had a huge delivery of parts to move on with steering position and etc. Rads drawn up. just gotta send it into PWR for final sorting and they'll knock it up, motors of for machining. Front end is fitted up, just have to mount the upper shock mounts, still awaiting my drag link and Tie rod. I have to ring them, apparently the lads are meant to call me but I keep reminding them and not a word.
Still haven't made my mind up about the 2 door conversion, I really wanted to have this thing a 4 door and so my wife, kid and I can enjoy it. And for drag challenge style racing. But there will be little access available via the rear doors from the cage. if
i make it a to door, it'll become a 2 seater as there will be know access to the rear seats,
Tappet Head
Re: 1945 Austin 10
well still stalled, still waiting on Rod and custom to sort a few things out, this has now spanned over a few years waiting for them
Re: 1945 Austin 10
Wow, and no one else can sort it?
