Project 56 F100
heven67
Project 56 F100
Post by heven67 »
Hi Guys
Ive beeb lurking in the background for a while doing alot of reading about front end converions using Mitsi and Jag and holden and even the EL falcon conversion front ends as a substitutes for the original axel front end on my 56 F100.
I must say the info I have gathered so far has been great and I am looking to select a front end which will give me a nice ride up front.
Currently the vechile has the drop axel and leaf spring setup but is in LHD and I want to convert it,
So a few questions about whats what!
Mitsi front.....L300 front, what year model is the better?
I would like to put the steering rack at the front cause to what Ive seen (ie EL Falcon) the rack at the back gets in the way of the exhaust manifold and the steerin colum has to run through the floor, so at the front I can run the colum through the upper firewall.
Whats a L200? what car are they on? I noticed some saying these stubs have the steering arms facing forward as I need and If I turn the stubs around on the L300 the Ackerman angle is incorrect, I see some say to heat and bend the arms into the correct position, this is something I would only do if the engineer gives me the blessing to do.
So at this stage I havent even started pulling it apart until I have a good idea what way i want to go and then I will chat to the engineer and see what he wants.
No I dont have an engineer yet.
I thank you in advance for any help I can get.
Cheers Hev
Why stuff around with an l300 when you have to change all sorts of bits on it to make it work , by far the best choice of f/e for a 53 - 56 effie is the jag f/e .
Even the yanks are now catching on and doing jag f/ends instead of their mustang II jobs :wink:
Dave
Post by Dave »
Yep, on choice, Jag front end, and the US guys got the idea from us Aussies!
heven67
Post by heven67 »
I hear you load and clear...what model ect..Cheers Hev
Dave
Post by Dave »
Look for series 2 or series 3 XJ6 or XJ12, Jag or Daimler. These have the ventialted discs. Should be able to get a whole unit for around $400 or less!
Oldcol
Re: Front suspension setup on a 56 F100
Post by Oldcol »
heven67 wrote: Mitsi front.....L300 front, what year model is the better?
Cheers Hev
.....none..... :lol:
....you absolutely won't improve on a Jag for an F100 conversion......it's the best ,bar none.....
32coupe
Post by 32coupe »
Yep
L300=lots of mods, hard to fit=headaches
Jag=no mods, easy to fit=happy camper
Trust me, I've been there, won't even contemplate an L300 in an F1 again
Proud Oz-E-Rodders member
Oldcol
Post by Oldcol »
32coupe wrote:Yep
.....and I can refer you to a guy who will give you a similar unflattering reccomendation on the Falcon lightweight front end..... :roll:
Jag for sure. Finished one not long ago for a customer, Fairly easy fit and not wheel/ guard clearance issues. The only problem now is his mr's wants to drive it :shock: :shock: :shock: :D :D :D
krusty
Post by krusty »
jag wins hands down , ive got a 56 f100 here at the moment with a jag front in it , im in penrith if you want to drop around to the shop and have a look how its fitted and a general chin wag ,
ive also got a 55 f100 here that im doing with a c4 corvette front end
heven67
Post by heven67 »
Thanks guys...it looks like a Jag front then ..hey?
I seen a 55 with a falcon front and its too busy for me, and the fabrication was enormous..as well as ordinary welding, I figured "NO Falcon front for me"
mgtstumpy
56 F100
Post by mgtstumpy »
Know a fellow who put a Jag F/E in his 56 F100 and kept it LHD, just used a LHD US rack. Easy. Saved mucking around with the dash. :D
Re: 56 F100
mgtstumpy wrote:Know a fellow who put a Jag F/E in his 56 F100 and kept it LHD, just used a LHD US rack. Easy. Saved mucking around with the dash. :D
That's exactly what i'll be doing :wink:
heven67
Post by heven67 »
Thanks Krusty.....
Had a look around and am quite surprised at your work, will be in touch soon.
Cheers Hev
Theyeti
Post by Theyeti »
krusty wrote:jag wins hands down , ive got a 56 f100 here at the moment with a jag front in it , im in penrith if you want to drop around to the shop and have a look how its fitted and a general chin wag ,
Wheres the shop at Krusty I have been meaning to call arround since you made the offer last time and have been to Penrith during normal working hours a few times but I dont have the address
What Could Possibly Go Wrong
