38 ford coupe
Re: 38 ford coupe
Very nice.
Always wondered how tiles hold up to direct grinder sparks and using axle stands, jacks etc?
mercury mitch
Re: 38 ford coupe
Post by mercury mitch »
These are in garage not my workshop
robtus
Re: 38 ford coupe
Post by robtus »
You need some big chess pieces for that !!!
mercury mitch
Re: 38 ford coupe
Well i was not happy with the front of the bonnet, so out with the grinder
It is too fat where my finger is
and while the fronts out i will fit a spreader
mercury mitch
Re: 38 ford coupe
Cut and filed the hole for the door handle
And the handle made and polished
Re: 38 ford coupe
Those handles look interesting Mitch, any more details to share.
NashRod
Re: 38 ford coupe
Post by NashRod »
mercury mitch wrote:Well i was not happy with the front of the bonnet, so out with the grinder
Sort of looks like a big bonnet scoop :D
I agree that the curve didn't quite have the perfect shape so while it's at this stage cut it out.
Keep up the great work.
Chris
Re: 38 ford coupe
Going along great guns Mitch 8) 8) 8) 8) 8)
SimonG
Re: 38 ford coupe
Post by SimonG »
Not many people would have the courage to cut out that much so I am looking forward to seeing what you do to smooth it all out
Re: 38 ford coupe
robtus wrote:You need some big chess pieces for that !!!
Yes, when I saw the garage floor, I couldn't help thinking of this joke:
"Which way does one go?" "Any way you like maam. You're the queen."
mercury mitch
Re: 38 ford coupe
Well another day and another project,the water pump let go Saturday so it was time to bite the bullet and do the heart transplant
old one out, i have a new motor on the floor to go in and the gearbox leaks oil so everything out for a tidy up
mercury mitch
Re: 38 ford coupe
Well finally got the new motor in , gearbox rebuilt now a problem with timing pointer, it is straight under the water pump. I think it has the wrong timing cover , anyway it goes.
Re: 38 ford coupe
Excellent that it is running. :)
Should be pretty easy to work out a new timing pointer after turning the engine over to TDC.
robtus
Re: 38 ford coupe
Post by robtus »
mercury mitch wrote:Well finally got the new motor in , gearbox rebuilt now a problem with timing pointer, it is straight under the water pump. I think it has the wrong timing cover , anyway it goes.
Vacuum gauge works just as well.
mercury mitch
Re: 38 ford coupe
Finally got all the parts for the Windsor for the coupe
Bought these GT40P heads
