Coil spring rate calculator
YNOTU2
Re: Coil spring rate calculator
Post by YNOTU2 »
ram-rod wrote:hi Paul I think series 2&3 jag have different brake calipers from series 1. check the width of your discs with a set of verniers and ring your local brake place they will be able to tell you straight away If your discs are under size
sorry guys not wanting to take this off topic.
this calculator will be a very good thing thanks for taking the time fellas
Series 1- solid rotors : new 12.5.. Min. thickness 11.5mm
Series 2 & 3 Vented: new 24mm. Min. thickness 22.9mm
CHEERS,
Rod.
[url=http://www.ozerodders.com][img]http://i199.photobucket.com/albums/aa174/YNOTU2/oer-member.gif[/img][/url]
[url=http://www.rodsandrelics.com.au/][img]http://i199.photobucket.com/albums/aa174/YNOTU2/RODSRELICSLOGO31-12.jpg[/img][/url]
Warpspeed
Post by Warpspeed »
If you are running coil overs, there is a mob in the UK called AVO that stock a really good range of springs.
http://www.avouk.com/Downloads/AVO%2022 ... PRINGS.pdf
If there is anyone in oZ that offers a similar wide range I would really like to know.
Cheers, Tony
mgtstumpy
Post by mgtstumpy »
MikeSmith110
Post by MikeSmith110 »
Your Clac looks the go...I'll try of few variables that I've used over the years.
