Wife trying out the KBS Chassis Coater Kit.
A little update on painting the Willys chassis parts with KBS using a roller.
You have many hours of work ahead of yourselves.
I hope you can assist poor Lisa with the monumental task.
Finish with a roller is remarkably good.
Mudgy
Post by Mudgy »
Happy Birthday mate !
Mudgy
Post by Mudgy »
Gojeep wrote: Tue Aug 22, 2023 8:00 pm Update on the deconstruction of the Willys Truck.
https://youtu.be/SpNaEhBXwMY
Hi Marcus, to clean the alloy and not damage labels, have you considered dry ice blasting? Expensive, but might work best when disassembled to get at everything.
This is just an example.. https://www.youtube.com/watch?v=-O4gemWrn84
Takes off all the schmutz.
Cheers, Mudgy.
Mudgy wrote: Fri Sep 08, 2023 5:07 pm
Cheers, Mudgy.
Very 'cool'. :)
I used some of the phosphoric acid on it and came out quiet well. Just have to avoid any zinc plated fasteners.
zuffen wrote: Fri Sep 08, 2023 11:35 am You have many hours of work ahead of yourselves.
Because I didn't get sick while using the respirator, I will be doing most of it now. She will help when doing the frame as there is a lot to do at once.
We used a 3M one but was still some leaking around the top of my nose as have a sharp bridge. Anyone come across a better one if they have the same problem?
You might look into CPAP machine nose pads. they are used to seal between a CPAP mask and your nose.
https://www.amazon.com/Comfort-Avoiding ... 04&sr=8-38
robtus
Post by robtus »
Nice to see progress, you are very lucky to have such a willing (?) assistant. I agree with the amazing finish you can get from a roller. I did the underside of my body with POR15 and a roller, looks like it was sprayed in a booth !!
Watching and learning Marcus, thanks for the educational updates for when I get to that stage of my build.
51 Dodge Custom - Dare to be different
enjenjo wrote: Sat Sep 09, 2023 6:59 am You might look into CPAP machine nose pads. they are used to seal between a CPAP mask and your nose.
Awesome idea. I will try those for sure.
robtus wrote: Sat Sep 09, 2023 4:41 pm Nice to see progress, you are very lucky to have such a willing (?) assistant. I agree with the amazing finish you can get from a roller. I did the underside of my body with POR15 and a roller, looks like it was sprayed in a booth !!
Looks really great Rob. :)
Hope mine come out as well.
Sly Fox wrote: Sat Sep 09, 2023 7:04 pm Watching and learning Marcus, thanks for the educational updates for when I get to that stage of my build.
That is what this forum is about. Learning from each other. :)
Newbee
Post by Newbee »
Lots to do there Marcus, will you paint over it to improve the UV stability or are all these parts “hidden” ?
