I’ve got the car up in the air a little bit, to run brake lines. The front is done. The rear line is going to run down the passenger side with the fuel pressure and return lines. I will be setting the pinion angle and welding the spring perches while it’s up in the air too.
Dany
hudson nut wrote: ↑Thu Aug 01, 2024 11:48 am
IMG_1037.jpegIMG_1036.jpegI’ve got the car up in the air a little bit, to run brake lines. The front is done. The rear line is going to run down the passenger side with the fuel pressure and return lines. I will be setting the pinion angle and welding the spring perches while it’s up in the air too.
I'm still here. I've been sidetracked with a Hudson Hornet engine build for someone in the car club. I'll do a little build thread on it when I have some photos to post. Not much happening with the 54 at the moment.
Dany
Loving this thread. Really worth waiting for.
I've been a Hudson fan since my early Essex days, when I saw a "step-down" at a show.
Always wondered why guys rodded '49 (ish) Mercuries when they could same all that work and use a Hudson.
