HK Holden to ford stud pattern
chop_shop
Re: HK Holden to ford stud pattern
Post by chop_shop »
hi col,
yep, that sounds like simplest the plan of attack....
“Any fool can know. The point is to understand.”
― Albert Einstein
Oldcol
Post by Oldcol »
...and another one....
....the slightly longer than stock HQ hose we had made up so it mounts up on the frame.....no doubt someone will claim some sort of engineering issue here,but I've been doing these this way and having them passed without issue for a mightly long time.
...stock HQ hose on this one
Col....
"Works" comes before "looks good", cos "looks good" changes, and "works" works!
Oldcol
Post by Oldcol »
chop_shop wrote:hi col,
...yep simple beats the shit out of all else...no need to make a complicated saga out of this simple request I reckon.
Col....
monte
Post by monte »
Sorry col I wasnt trying to make a saga out of it, just exchanging information I call it. I think the girling calipers I have might be from a wb and are bigger than the hq ones. The ford wheel would not fit over the caliper. I tried it without the caliper and it bolted right up, so I guess the later holden ran 15 or 16 ins wheels :?: :?: :?: :?: :?: :?:
chop_shop wrote:Monte
Is the ford wheel rim different in its rolling / pressing or stepped in anyway to an original HQ one ? Might be the problem
14X7 12 slotters fitted my application.
If you go to "DBA" Australia.
They have an extensive catalogue on line for disc rotors . Every make and model from A-Z . Each rotor has every dimension including wheel hub size and number of studs . Handy to print and keep for 'research" .
chop_shop
Post by chop_shop »
Actually good thread...
Thought i might get shit canned based on the Ford vs. Holden debate
Wonder what the response will be if i drop a Clevo donk in it .... ;) :)
monte
Post by monte »
chop_shop wrote:Actually good thread...
Windsor might fit better :lol: :lol: :lol: :lol: :lol: , love it :lol: :lol: :lol: :lol: , bet thats never been done :lol: :lol:
62 Efee
Post by 62 Efee »
Yeah Monty, it's been done. a 351 Windsor but in a HQ.
Not me but someone that liked being different :D
You can throw all the philosophy you like at the problem, but at the end of the day it's just basic
rog
Post by rog »
62 Efee wrote:Yeah Monty, it's been done. a 351 Windsor but in a HQ.
Done well before that.. People were putting y blocks in fj's :D (just a little bit refreshing from all the chevs in fords, lol)
Yup back then when this was attempted/done ,all that was easy to obtain and affordable for V8 wanters was the Y Block . I remember around 1968/69 at the East Sale RAAF base inside a hangar known as "The Hobby Hut" where we could repair our vehicles and boats etc ,there was an FJ project sitting with a Y Block in it . This vehicle was covered in dust and most likely belonged to someone who had abandoned it after being posted out to some other base .
SBC became fashionable and more abundant and affordable into the 70's . They were also the most friendly engine swap, thus the popularity .
mgtstumpy
Post by mgtstumpy »
As Col stated P76 are the go as they are Ford bolt pattern, plus you get a narrower front track. Holden calipers are used. RodTech make a kit however I'm not sure if DBA rotors are still available?
YellowUte
Post by YellowUte »
Btt
Fingers
Post by Fingers »
XR-XT hubs will fit, and take the HK disc easily, BUT they are too hard to find.
Richard Seymour
36 roadster
Post by 36 roadster »
Fingers wrote:XR-XT hubs will fit, and take the HK disc easily, BUT they are too hard to find.
Are the disc mounting holes in the same spot?
.....insert witty comment here.....
