HQ - steering box exploded diagram?
Jeff Hitchins
Post by Jeff Hitchins »
Hi Guys
Does anyone have an exploded diagram of the HQ type steering box they could share or point me to a link to one.
I have done a google search but no luck so far.
I am particularly interested to find out which way the main shaft ball bearing races fit - there is one at each end of the input shaft and they could be fitted either with the taper facing inwards or taper outwards
Cheers Jeff
UEH000
Re: HQ - steering box exploded diagram?
Post by UEH000 »
Hi Jeff
Have a scan of the diagram but can't pm you and don't know how to put pdf in this reply.
But moving inwards from the adjuster nut you have cup- bearing - worm ball nut assembly- bearing- cup- retainer - seal.
Hope that makes sense.
Cheers Lindsay
Post by Harv »
Hope this helps.
Jeff Hitchins
Thanks Lindsay and Harv
That is exactly what I needed to know.
I very much appreciate your help and reply
Cheers Jeff
