ram-rod wrote:hi Paul I think series 2&3 jag have different brake calipers from series 1. check the width of your discs with a set of verniers and ring your local brake place they will be able to tell you straight away If your discs are under size
sorry guys not wanting to take this off topic.
this calculator will be a very good thing thanks for taking the time fellas
Series 1- solid rotors : new 12.5.. Min. thickness 11.5mm
Series 2 & 3 Vented: new 24mm. Min. thickness 22.9mm
CHEERS,
Rod.
[url=http://www.ozerodders.com][img]http://i199.photobucket.com/albums/aa174/YNOTU2/oer-member.gif[/img][/url]
[url=http://www.rodsandrelics.com.au/][img]http://i199.photobucket.com/albums/aa174/YNOTU2/RODSRELICSLOGO31-12.jpg[/img][/url]
